Ive used the RightStuff on 5 sets with no leaks from the outer bead. I prefer to use sillycone. 1/4-3/8 bead just inside the weld on the ring. I use 3 buckets to hold the tire off the ground and let the rim slack down to have room to work. Then trying not to smear sealant i pick it up and set the rim on a bucket letting tire rest on outer ring to bolt the rock ring on.
Ive also done a few sets with no sealant, one set I had to redo with sealant and I got lucky on. These are all weld on beadlocks from 34s to 40s. Never used sealant on any of the H1s or manufactured beadlocks like Racelines or such.
Milling was a pain. No good way to hold it down with the stuff I have. Really close to fitting on the lathe.....back to grinding yay. Wheeling next weekend so gotta get er done.
I was lazy and left my spare shafts in with small ujoints and snapped it. Hit lower ball joint. Not sure how knuckle or inner c is. Without weight on tire the ball joint unseats.
I'm having problems with spicer ball joint again. My upper came loose a while back and was turning with the kunckle. I was in a hurry so I just got a valucrap from autozone and it fit fine. The lower that got hit by the axle shaft was a moog but I didn't want to reuse it after that situation so I was going to use a new spicer I had laying around but it's loose in the taper just like the upper was. When I put wheel on it slides out of taper. My upper bj has enough vertical play to let it. Thinking of trying a different bj in lower. I really don't want to go through the trouble of "building" another dana 30 just to destroy it but I don't see much benefit in doing a d44 and I definitely don't have the cash to build a 60 right now. Any advice is appreciated.
