old_man
- Loveland, Colorado
Arms as you have drawn them are a bad idea. I tried it about 15 years ago before I realized that the reason there are only three sides on the OEM arms is so that they can twist when you flex. The bushings can't handle all the flex themselves. I welded up a set and they didn't last one rock crawling run before torquing so much it tore the welds off the ends.
For the mall they would be fine, but on the trail, you need more flex. If you make them so strong they won't break, you won't have much flex.
