Sniggs
- Western Washington
Also check with Red91inWA - he's down your direction.Avanteone said:PM WSUXJER on here, I think he still has his XJ D44 for sale.
J
J
Sniggs said:You get yours on the trail yet?
I've noticed that it doesn't matter if your locked or not, your rig always wants to go straight. That's how this happens.TORX said:It looks to me like a lot of the NWC is running auto lockers in the front. For those people running them, how do they affect you on snow packed roads and cornering?
I remember reading a thread quite awhile ago that said, with a Aussie or similar design locker, when you go to turn on packed snow your rig still wants to go straight? Would you call this "myth" busted, plausible, or confirmed
Lockers for me are far into the future, but Ive always been curious about how the autos work in the winter.
TORX
is it just me or is that just a red X ?PoSxJ said:I've noticed that it doesn't matter if your locked or not, your rig always wants to go straight. That's how this happens.
mojojojo said:so so do you guys think i will see any major benefit if i go with the aussie front and stick with my LS rear, while i am hunting for the 44 rear?
FiFo said:Spending money on a D35 is just waising money that could be better put towards getting a D44.
There are some Yukon shafts for the D35 on Ebay that are supposed to be 30% stronger than stock.FiFo said:Spending money on a D35 is just waising money that could be better put towards getting a D44.
falcon556 said:There are some Yukon shafts for the D35 on Ebay that are supposed to be 30% stronger than stock.
The biggest problem with the 35 is that the shafts break.
falcon556 said:The shafts have the spline count and diameter of the D44 and made of better steel than the D44.
falcon556 said:The biggest problem with the 35 is that the shafts break.
goodburbon said:he's talking about the super 35 kit
Avanteone said:You had a good plan worked out in saving for the D44, don't confuse yourself now J
mud1059 said:I'm not sure if this was brought up yet or not but Petersons 4 wheel did a great write up on upgrading the 8.8 for jeeps. It included a kit from Superior that made it semi floating, 30 someodd splines and extended the axles to the D30 lengh. All done with regular hand tools. I think the kit was only $560.
I run a D44 and my biggest concern is replacement parts. I'm never going to find stock shafts or housings at a reasonable price because the 44 is obviously extremely desirable. Just pointing out a few things.
edit: There's more to the Superior kit, however I don't recall everything.
PoSxJ said:I've been told that if you plan on upgrading to the 8.8 you might as well go with a 9". Similar fabing but a stronger axle and more aftermarket products. Plus they're easier to find. Though I could be wrong. But there are is a lot more coming out for the 8.8.
