yes but you did not retain the factory mountsTazXJ said:I have '96 ZJ limited front leather seats that are 100% functional (power, heated, lumbar), AND '98 ZJ rear leather seats in my XJ
red_01_xj said:yes but you did not retain the factory mounts
yep didnt you use the ZJ bases/tracks, then yours woudnt be bolt inTazXJ said:XJ factory front seat bases/tracks?
krelja said:I didn't see how the power bases would bolt to the XJ bases and still have all the power options work. I just chopped the brackets off of the WJ seats and made some that would lower the seat a little and let the seats go back farther. The back took a little work but they are in and work great here are some pics I have no real write-up or anything and I can snap some pics if you want more
click to enlarge
at least to my knowledgecklaus said:The Orvis ZJ seats are six way power seats with motorized recline
guess they won't work. http://www.jeeporvis.com/1996-7-orvis-info.html
red_01_xj said:yep didnt you use the ZJ bases/tracks, then yours woudnt be bolt in
mine had manual recline, and non power slide, the heat works, there was no lumbarTazXJ said:OH....yeah I see what you mean, I got confused there for a min. you would be correct, they aren't exactly a bolt in deal, I had to re-drill a few holes.
that reminds me, are your WJ seats 100% functional like my ZJ seats are? my heat/recline/lumbar/power slide/etc works like factory.
if you add the channel like in the 95 plus and then used 95 plus seat frames and grand cherokee seats you should be able to do itbn6339 said:Read this thread a bit...does anyone know whether grand seats will fit an MJ? Im willing to do some fab work, just nothing horribly beyond my (non)welding skills...TIA
red_01_xj said:if you add the channel like in the 95 plus and then used 95 plus seat frames and grand cherokee seats you should be able to do it
You would need to use the MJ seat brackets. The xj ones are different.bn6339 said:Read this thread a bit...does anyone know whether grand seats will fit an MJ? Im willing to do some fab work, just nothing horribly beyond my (non)welding skills...TIA
