Chero-King
- Up here eh?
Big Red said:Does it matter if they are from a V8 or straight 6?
Well the straight 6 Coils only barely give you an inch. The v8 coils I'm pretty sure give around 2-3"s
all except the bracket between the seats (for the 40/60) are attached to the seat...and this one is bolted in as well...i believe the nuts are welded so you will not be able to get thoseJEEPZZ said:So other than the rear seat itself, what other pieces from the WJ will I need? Just the brackets??
I'm assuming that the mounting brackets will unbolt out of the WJ -or- are they welded in there?
the heated do not...but cloth Grand cherokee seats are way more comfortableAlienspecimen said:Do the Grand Cherokee heated seats come in non-leather version? I hate leather...
Thanks
Boris
Chero-King said:Well the straight 6 Coils only barely give you an inch. The v8 coils I'm pretty sure give around 2-3"s
up country ones will give you an inch more than stated above...my V8 coils gave me about an 1.5"91 Jeep Project said:Nope, 4.0 coils give you nothing. V8 coils only give you an extra inch. If you don't already know this, it's easy enough to figure out. As the Rubicon 4.5" ZJ Coil is the same one they use as the XJ 5.5" Coil.
91 Jeep Project said:WJ seats raise you up about an inch, XJ power bases raise you up about an inch. Depending on your height, that could be an issue.
lil98xj said:Anyone know if ZJ non-power cloth seats raise you up? I have a lead on some locally and am wondering.
Thanks!
Dennis
91 Jeep Project said:As far as I am informed, no, they do not.
lil98xj said:They also seem to sit farther forward giving the backseat a little more legroom. I saw this as I watched my 5 year old climb into his car seat.
Root Moose said:Excellent. How did it affect the driver's leg room?
Being long of leg and I can just get comfy with the seat all the way back. Does the extra height offset the leng room loss?
When my boys get bigger the rear leg room may be an issue for us.
Yes, I know for sure. Sorry, I didn't make it up. I said that the Rubicon Lift coils for the ZJ give the XJ an inch more lift. Which is why the Coils included in the RE 5.5" XJ kit are 4.5" ZJ coils per the part number. Not enough proof?miketyson said:That doesn't make any sense, Aftermarket springs by companies like RE don't specify I6 or v8 so if youre saying the factory coil on a v8 is stronger then w/ aftermarket coils a I6 will always get an inch more lift which i do not believe to be true..
logically i agree the v8 coil should be stronger but this just doesnt make sense to me, anyone know for sure if theres a difference?
The XJ bases need to stay, any year ZJ (93-98) or WJ (99-04) will bolt to the XJ bases.1bolt said:Yeah this is probably the 10th thread I've read about WJ/ZJ seat swaps into 95+ XJ's Over the past three years. I ended up adapting passenger car leather seats into my XJ. and I'm still not sure what years of grands fit and whether the XJ base needs to be retained or the wrole grand seat bracket bolts in. Now I got a 97 for my Wife with power everything but cloth manual seats... looking to change that.
