mikedashg
- San Diego, CA
ah, found them in the prothane catalog.
Now, just gotta find out who sells the darn things
:thumbup:
They work pretty good. You need to modify the frame side bump stop so you don't 'harpoon' the prothane coil insert.
I know it is REALLY hard to see it but if you look carefully you might notice I cut the 'knub' doen, tapped it, and placed a 2" x 1.75" (I think) plate on it.
Even better, this place is local (to me, San Diego), they'll have em in 5 days and I can pick it up.
http://www.ajusa.com/browse/brand/2/PTP/0/0/0
Get the longer ones and cut them down. They also compress quite a bit, mine compress 3.5".
:doh: :doh: :doh: :doh:
Just ran the part number on the Bilsteins I had up front 170/60
I got these used, and I swear the prev owner told me they were 255/70. I guess I should've looked for myself.
I can't beleive I was running down Boone Rd with Rusty's coils and 170/60 with a winch and a winch bumper. No wonder it sucked ass
Moving on, thanks for your guys help
I got the 5" ones. I can put some hockey pucks under them if I need more.
FWIW - I've never ran with the 255/70 valving in the front of my junk, but I was REALLY happy with the 275/78 valving in my 7100's...
When I was buying them, I sent a PM to Jes asking about 7100's, and he said he had run both valving, and there was a noticeable performance gain with the 275/78...
Edit: all of that info pertains only to the front of the jeep - in the rear, the 255/70 might be a bit better...
I'm running 360/80 7100's up front. I like them ALOT. They aren't too harsh for the streets but work great in the fast stuff.
Nope, they won't compress enough, or be progressive enough. Mine are the 10" and I cut them down to 9", and they regularly compress 3-4" to make them nice and progressive. I can hit hard and can't feel it bottom out. They don't have a positive stopping point to protect you from bottoming the shocks, so you need them long enough so you can play with it a little to get them the right length. I have 6.5" of shock shaft showing on the 7100's and only 2" of uptravel before the bumpstops hit, they're that progressive.
:thumbup:
Mine were cut down about 1" as well. Worked pretty damn well.
5" are probably too short.
My fox's are for sale mike, and they've done me pretty well in the go fast stuff
:thumbup:
