FordGuy
- San Clemente, CA
This summer, I just need to mount the shock inside and gain some travel, at least 12 in the rear and then I can run 14's.
my problem is if I go to some good deavers or nationals, It is going to totally suck when its loaded down or have passengers. Tough call.
I'm not sure what makes you say that ? I have Nationals, and have filled mine to the max(#3 on the way) and tow my camper with it. No problem.
What valving on the 7100s?
Are you talking about some real whoops 2-3ft deep or some little whoops, becouse I know I cant run 25 in the real whoops
I say that because the spring rate you would use to have max travel/droop with maximun progression are very soft. 100 lbs in the rear would sag it 4 inch's
Deaver springs are great both fast and crawling. Tony and I run them and I dont think Tony had any complaints, im sure he will chime in. And you have seen Tony Wheel his junk. Might want to look into them
Cal wasn't there and you nor Cal was going 60 over that stuff :looser:
Full bodies not made for Jeep Speed don't do 60 on that stuff. No one out there is faster than Dave and Paul and they peak out at 60 on that stuff.
my passenger seat runs with ryan brown say otherwise.....
I will NEVER get in ANY car when Ryan says, hey put your beer down and let's go for a cruise.. :scared:
I've been a passenger in his rig twice - once on the dirt and once on the street.. :scared:
lol..... Ryan - :spin1:
E
I can't take idling through the whoops anymore. The end of Boone Rd and the road back from the hammers is just brutal. I'm lucky if I can get over 12MPH. I need some help from the speed community. What should I get? I don't have a crazy budget, but I want to be able to get some speed up across the whoops.
Right now up front I have Rusty's coils (netted 5" lift with extra factory isolator), Bilstein 5125s (11 inchers I think), RE superflex adjustables upper and lowers with drop brackets.
In the rear I have 1.5" Daystar shackles, 5.5" skyjacker leafs, and Bilstein 5150s (10 inchers IIRC).
(BTW, this is in SoCal and not tech, because people in SoCal know what "THE WHOOPS" are when I refer to Boone Rd and JV)
Probably the little ones. The big ones scare me... After you make the left turn around the hill going back to camp you can keep the speed up for awhile, but there are a few sections where they get deep, and I slow down after landing. That's where I broke a center pin.
Mike, I haven't read all the posts, so don't know what other people have already said, but here's my suggestions. I'd go with stiffer coils in the front, which aren't expensive, I don't think the Rusty's are very stiff. Stiffer front springs don't hurt you on the trail but they do better going fast and add road stability. I'd also get a pair of the Prothane coil inserts for bumpstops, these things are worth their weight in gold, and they're also not expensive. They sit inside the coil and are very progressive, some desert guys call them a poor man's air bump, I have them on my XJ. Next I'd go with some stiffer front shocks, like the 7100's in the short body version. The 5125/5150 series all come with the same valving (hopefully you don't have the soft valved versions which are meant for dual shock setups), which is pretty good for the rear but it's too soft for the front. The 7100's with stiffer valving work much better.
For not much money you can get stiffer coils and the spring insert bumpstops, which would be a big improvement.
No
http://www.prothane.com/productguide.php
I can't find them (anymore) but troy has a set he may sell you (my old ones) if he doesn't use them.
They were VERY difficult to get when I got mine. Took like 5 months :shocked:
