terryd said:
Well, after two days of trying to get the SWR down, I'm still not getting better than 3.3:1 with a 3' fiberglass whip turned all the way down and a spring. I'm considering a taller, top loaded Firestick, something like a 5', with a heavier spring to try to get it down. Any other suggestions from you guys? I talked to a guy at a local CB shop and he was just pissed about where I mounted my antenna and basically refused to do anything but tell me to move my antenna. :helpme:
The other members have made quite a few recommendations, but....the first problem is obvious... while you did a nice installation.... you should consider moving the antenna to the center of the roof. This is the best location for transmitted and received signals.....
With your antenna in the location it is...; received and transmitted signals WILL be directional... This means you will hear transmitted signals from behind the vehicle very well, but ones from the sides and front will be dramatically decreased.... and your transmitted signals will also be heard mostly from behind the vehicle...
With high SWRs readings like that.... I would remove the 90* connection from antenna and then read the continuity with a multimeter to ensure there are not shorts to ground or between the center core lead and the ground shielding. IF infinity is read; as it should be... then check the SWRs at the coax connector that attaches to the radio. IF SWRs are still high... then you need to run a braded grounding strap from the uni frame (ensure good clean connection) to the antenna mount. This will provide a larger ground plane and give your antenna some load using the vehicle body....
Wilson makes a antenna that is used by truckers with an extension shaft that will move the base of the antenna to above the roof line..., but this will stress your existing mount....
The setup I have run for 11 years on my '98 is a Wilson 1000 magnet mount located on the center of the roof. The radio I use varies from either a ICOM IC 706MK2G, Cobra 148 GTL SSB (old style) or Uniden Grant LT SSB along with a Yaesu FT 2200 2 meter...
I can talk as far as I want and when I am in mountains I can talk as far as conditions allow....
Remember... the ANTENNA makes the system... A good quality antenna will make a cheap radio perform well, but a cheap antenna will make a quality radio perform poorly....
All depends upon what you are trying to accomplish and what your needs are; as to how much you spend and where you locate your antenna.
