terryd
- Elk Creek/Covington Va
I'm going to the local TA truck stop tomorrow morning to try to pickup a Firefly top load. Thanks for the help guys! I'll report what I find when I get back in town!
bosco01xj said:where did you get that metal strip?
FlexdXJ said:Just installed my CB yesterday. Unfortunately some jack ass drilled a hole in the roof for the one thats there now its just a little foot-tall antenna. I don't wanna take it out just yet. I thought about maybe a 2 foot firestick
Mudderoy said:Sounds like a 2 meter antenna or a scanner antenna. You should be able to find a plastic plug made to cover that hole. Check with an electronics store that carries ham and scanner antennas.
terryd said:Well, my antenna mount broke the other day. The aluminum cracked in the top 90* bend and dropped my antenna down behind the jeep. Luckily it was on the trail and didn't hurt anything. I'm going to try to re-do the mount out of steel, probably a little thicker this time, and see how that works. I'll keep you posted.
xjtrailrider said:Terry, I noticed on the Bobcat ride it was getting floppy at the mount but it looked more like it was flexing the rear hatch. You may want to use a steel plate inside the hatch to to spread the load on the sheet metal or use a spring to soften the shock to it.
I know you are aware that most of the trails we run around here are antenna killers, thats why I put mine on the front and with a light spring so I can keep an eye on it and if i do whack something with it, it will just pop back.
We need to get together on another trail ride soon!
Jon
