thats how far the yoke is out...less than an inch is in
I think this is where it needs to be located, but the tranny has to drop or driveshaft lengthened or both.
so I had some tranny drop spacers made from 1"OD, 1/4" wall, 1/2" OD tube...1.25" ones.
only broke 2 bolts off, the other one is removed thanks to my dad's welding skills (built it up and removed with vice grips) and the other one will be done next.
here's pics...it had studs on the driver's side frame for the crossmember, they had to go for the drop kit to work...so they did but the nut for one broke off.
fixed it this way.
then just welded that stud down...
spacers 1" OD, 1/4" walls, 1/2" ID
completely installed crossmember
d-shaft will gained 1.25" or more of input on the slip-yoke from the drop
so it's dropped.
in the morning I will re-center the axle, then use the pinion angle gauge to set the rear axle to match the output shaft, pull axle after tac-welding it in, then have dad full weld it paint it and reinstall it.
will be doing rear brakes tomorrow too and also dropping the e-brake assembly.
whatcha think?
