Update: I yanked up the rear carpet just now, and even though it's dry on the top part, the padding on the underside is still wet. Damn it.
Haven't done the roof rack hole sealing yet, though I bought the gasket material today. Also noticed this, and wanted to run this thought by you guys:
The rear latch (which is at eye level when the hatch is open) is very rusted. Also, the rear pin and the plate (with the two T-40 bolts in it that won't come out right now...broke two T-40 sockets within the past hour, trying to loosen them) where the latch catches to close/lock the rear deck is rusted as well. I've opened the rear hatch on many occasions and seen water pooling at that pin/plate. Happens every time I wash it basically. Dry it off, open hatch. Soak up standing water from around the pin.
There are no clean lines where water has run down on either inner metal rear wheel well. Still very dusty on both of them after pulling up the carpet. I would have thought that if the water was coming in the roof rack holes, it would have run down the inner wheel wells and left lines in the dust. Didn't see any. In fact, the carpet (both sides) that sits on the inner wheel wells is completely dry. Hasn't been wet at all. And believe me, if it had been wet, you'd know it. It's a different color where the water has been. And smell. The carpet on both wheel wells is still dry & clean.
So...I wondering if somehow the water could run around the rear hatch and collect at the pin in the little recession when the catch grabs the pin. Then maybe leak around the pin, under the plastic rear hatch bottom molding, and to the carpet. The carpet is wet from the rear door to where the rear seat pegs go into the body. Wouldn't the gasket on the rear door channel water around to the pin to collect? Anyone else finding their pin/plate/catch are rusty from sitting in water?
