generalleexj
- virginia beach
ok quick question, on the bottom of the sway bar links on a 01 cherokee there is a TORX bolt which holds the sway bar to the axle, is this bolt threaded in there? is it welded? or is it just pressed in to that metal ? im cuirous because i jumped my jeep today and broke the after market adj. sway bar disconects and it bent the metal arm that holds it to the axle toward the driver side. so i just need to heat up the metal, and beat it back to place.
