a7273chargerguy said:the only thing i learned was"i need a locker,d44 and 35's"or a winch.
You need more than that and it's something you can't buy.
karstic said:You need more than that and it's something you can't buy.
As you said, you use them as hold downs, not for trying to yank a vehicle out of a mud hole.camarors8992 said:Why are you guys so terrified of using chains to pull a vehicle out ? We use them in construction to hold down the dozers and excavators to the trailer. Also, if chains were that unsafe, then why on a 25 ton trailer do they require a safety CHAIN, not a safety STRAP ? Just curious ? I think you guys are over doing the don't use a chain fear.
TheRangerStation said:[FONT=Arial, Helvetica, adobe-helvetica, Arial Narrow]Towing with chains[/FONT]
In a word...don't. Towing with a chain, in most cases, can be dangerous. Unlike a tow strap, a chain does not stretch. Under the tremendous loads of towing, something needs to have a little flexibility, hence the tow strap. By using a chain, there is nothing in the loop that will give a little. What this means, simply, is the weakest part will break once sufficient stresses are imposed. This could be the chain, the tow hook, or some other part of the vehicle. Can you imagine the force behind a chain link being thrown at you by a force of 8000 pounds? Chains have their place for the off-highway driver, but not in towing.[/FONT]
thank you.chains are safe unless you have a friggin' dinky little 1/4 inch bolt holding the hook to the chain.camarors8992 said:Why are you guys so terrified of using chains to pull a vehicle out ? We use them in construction to hold down the dozers and excavators to the trailer. Also, if chains were that unsafe, then why on a 25 ton trailer do they require a safety CHAIN, not a safety STRAP ? Just curious ? I think you guys are over doing the don't use a chain fear.
a7273chargerguy said:thank you.chains are safe unless you have a friggin' dinky little 1/4 inch bolt holding the hook to the chain.
i use straps too usually.but this particular instance i had snapped all the straps so i had no other option.if it would have been a f-250 pulling an f-250,then ya,duh,no chains.but my cherokee?soaking wet maybe 2500-2700lbs(someone correct me if I'm wrong on the weight)i see my jeep snapping in half before a half inch chain breaks.ready to mud said:i personally use straps and prefer them as they are safer and nicer to work with. but at the same time chain is also safe IF it is rated good enough. where i live we have lots of oilfield roads that are all mud and lots of massive lifted trucks. most companys around here only use chain to pull people out and will not do it with a strap. the difference is that they have a rule of minimum half inch chain. they say they have had to much damage done with smaller chain and straps(obviously not enough capacity)
Is the lesson.Speed_racer said:NO METAL DURING EXTRACTIONS!
thats the most retarded thing i have ever heard,you used a d-ring between 2 straps,no shit it's gonna fly.How can you even relate that to chains?here's how my hooks are mounted.it was like that when i bought it.Speed_racer said:x398123789 on NO METAL DURING EXTRACTIONS!
Thats what happened to me... now listen to the story...
Stuck XJ > Strap > D - Ring > Strap > Non-stuck YJ
After the strap on the YJ side gave, and the D-Ring went THRU my hatch... blew out back window... strap flew inside, you could HEAR the d-ring rip back out, and get carried into the cab by the weight of the strap, where it DINGED into that THIN METAL BAR inside the CENTER of the headrest....
Yes... Speed couldve actually DIED from getting unstuck....
NOT WORTH IT, IMO!!!
