703's Made My '91 HAPPY!
OK folks,
All this talk made me dizzy so I just went and bought the Bosch 703's set and threw em in, pulled the neg cable, shorted them, and have driven 22 miles so far.
My XJ starts easier, runs Noticeably smoother and has an obvious increase in performance. I drive up and down a mountian everyday for work with lots of steep and tight corners. I do have other bolt-ons, like a cold air intake, full exhaust, 62mm TB, JET chip and Super coil. No matter, this was an obvious improvement and my XJ is very happy now!
I did clean up the ports real well while I had the injectors out also. Brake clean on a Q-tip and a smooth wooden dowel for the harder stuff. I was out of carb/injector clean spray.
If you are comfortable doing this job I say go for it! I spent $100 for the set of 703's tested, flowmatched etc. I just pulled the throttle cable bracket and breather hose and was able to manuever the rail around the TB and such.
Thanks for the heads up! :cheers:
