JaVeLiN
- Slough House
OMG... 425,000 miles !!! The 4.0 is stout?
I picked up a set of 703s from the JY. I'm plan to clean them and put them in this week end but I'm having trouble finding the little plastic hat shaped caps at a parts store. The stock Jeep injectors have a ridge cast into them instead of using the plastic set up. Does anybody know what they're called and maybe where to get them? Do I even need them?
They are called Pintle Caps and Napa carries them. Make sure to take atleast one good one with you so you can match it up with the right ones.
Wrong.Everyone on here arguing about 24lbs/hr injectors for strokers are thinking of the mustang injectors which are rated at 24lbs/hr at 43.5psi. Again 43.5psi is the standard fuel pressure that injectors are rated at so manufacturers have a standard to work from when doing their own math to match fuel needs.
A variety of reasons dictate what injector they use. Not just the fuel flow. For example both the 4.7L and 5.2L/5.9L engine use injectors that flow ~24 at the fuel system pressure. The PCM is tuned for the correct injectors.If these injectors are way over rated why would they be in 2.4L dodge engines?
Wrong. A variety of reasons dictate what injector they use. Not just the fuel flow. For example both the 4.7L and 5.2L/5.9L engine use injectors that flow ~24 at the fuel system pressure. The PCM is tuned for the correct injectors.
