- Colorado Springs, CO
Yeah, and change your screen name. The whole reason I'm in this thing is because my 90 XJ has been the most reliable vehicle I've owned. :laugh3:
Fred
Fred
90xjpos said:thank you soooooooooooo much wilcharl. i jumped that wire and it turned. all the auto parts places are closed for the day and i dont have the connectors or enough wire to run a new wire yet. but i got the old one out and fishing line in place to pull the new one threw. so now if this dosnt work. how do i bypass the NSS. for $300 they can keep the darn thing i am the only one who drives it cuz i just bought the wife an '05 xj so she has her own toy. and i am not stupid enough to try and start it in gear. so just so i am prepared can someone give me directions on how to bypass that silly thing, just in case. i would greatly appreciate it. thank you all so much. i would be stranded without you all.
90xjpos said:ok well a buddy of mine had all the stuff i needed to run the new wire. and i got it done. now i still have the same problem. i stick the key in and try and start it. and.......................... nothing happens. the coolant temp guage goes up and thats it. so i guess then the next option would be to bypass the NSS temperaraly to see if that fixes it. i dont think it will though because the relay is grounded to it. so if that was the problem then wouldnt it not turn over? to be honest i have had about enough of this. anyone ever seen the push button ignition on a SRT-10 ram. i am about to copy that idea if this dosnt work. from the best i can figure out all i need to do is run a wire from the positive on the battery. to a push button switch in the cab. then the return to the I post on the starter relay. anyone has any warnings lets here them now because the auto parts stores open tomorrow at 8 and i will be the first one through the door if nobody has any other suggestions as to what can be wrong.
