Panama XJ
- Panama, Central America
Check for a crack in the fuel regulator diafragm it can leak lots of fuel to the intake manifold
90xjpos said:If the fule pressure regulator diaphram is cracked. would that cause the pump to keep running like it is? what is it that tells the pump to stop priming like that?
HossHoffer said:Yes, as a matter of fact that is how you tell that the diaphram is cracked. Check that out asap. There is a bleed down test for the fuel rail but I can't remember it offhand. That would let you know for certain. I'll try to find it and post if you need it.
