All the pics work for me.
JFYI, I think that's a "cast wedge" dana 44, they are usually a lot cheaper than the welded-wedge ones because you can't cut the wedges off, so you are basically stuck with the Ford radius arm setup. Fine for you probably since you are going for a desert build and probably don't need much articulation in the front, but it's something to keep in mind, especially when designing your front suspension.
Finally located some radius arms for the front Dana 44. Just have to clean them up and begin deciding how I am going to mount them. I am torn between using a true Johnny Joint or a Heim Joint. Any thoughts?
Hiems cheap and tough
Yeah but what about the ride. I am building this for the desert. Most trips take 10-12 hours just to get where we are starting. I have been looking around and most are saying Johnny Joints ride better. I am wondering about durability though.
Homes shouldn't be to bad it used that big bushing at the axle end. And it will be more durable I believe.
I have held both. Sorry I suck at spelling. I prefer hiems, they seem tougher, and I have seen them hold up to a retard on 39s. I like them, I will be running them my self soon hopefully.Have you run either? Have you even held either? And it's "heim" joint, not home or hiem.
