tow hook
- western pa
LOOKS GOOD, i like the idea of making my own u-bolt flip kit. looks like 3/16 2 x 4" square stock. or is it thicker ?
Thanks man!! Its 3/8", 5"x5" OD, 6 1/2" long.. Worked out great!
HUMM. i'll have to track some down.. it seems cheaper to build then pay 139$ + shipping for it.... thanks
...but the tools i get to keep...
id be lying if i said the thought of 35s hasnt crossed my mind... i think once the bushwackers flat fenders go on ill know for sure!!! your just fueling the fire!! lmao!!!Nice work man! I want to swap JK axles under my XJ as well. I want Rubi 44s unless I can get a sick deal on a JK 30/44 pair. I'm planning on running 35s though. Your work is very clean / simple, I like it!
Nice job with the plumbing. What did you us? re-purposed front lines?
Thought so. Looks very clean. When I did my ZJ conversion I had a hard time with positioning the soft lines. I used OEM ZJ rubber lines. Eventually I welded a couple bolts to the axle housing, threw the tab on the soft line onto that & double nutted it. Works, though I'm not sure I have enough slack in the lines.
I like your solution better. Honestly, it ought to be integrated into somebody's rear disc kit.
