XJ&CHZ4ME
- Unionville, MO
when debaing over chicken or beef for dinner, do so when not on an aggressive climb.
bring spare valve stems, too.when you air down, don't forget to put your valves caps back on.
mud and sand get in there and you will have troubles airing back up.
Have your tow straps and d-rings where you can get at it easily. If it is in your cargo area, and your under water, or mud, or climbing a rock wall, getting to it will not be easy.
BOB
When you get out of your Jeep on the trail, make sure it is not in gear.
Rev
BOB
Don't forget to pick up a bicycle flag from somewhere and mount it to your junk.
It will cost you substantially more if you need to buy one at the Badlands. It is required.
87 "$25 for a FLAG!" manche
when you are on the trail you must communicate with
each other through your CB radio. Each group will chose a different
numbered channel. you must follow the person in front of you.
we have had some problems with people moving too fast and losing others in the group. to avoid this you must tell communicate closely with the guy in front and the guy behind you. do not go to far away from either driver. try to let them know where you are. to slow down and wait for you.
also when the person in front of you go over an obstacle. like a hill. wait for that person to get to the other side. when he gets to the other side, he should call your name and say "clear". then and only then should you proceed. You need to do the same for the driver behind you, when you get over the hill.
BOB
Also make sure your cb works..........Bob!
wasn't it you Aaron, who led half the group behind some Wrangler and got lost last year?!?
BOB
...also when the person in front of you geso over an obstacle...
BOB
BOB
Nope, that was Josh! :laugh3: I had to gun because he got lost.
The guy in font of me(5speedxj i believe on another forum) didn't have a cb and started following a wrangler
I will have a solution to that this year.
hopefully you guys aren't color blind.
Wait, is your jeep brown or burgundy?
