mitsumotors
- Winnipeg
I got this info off of ajeepthing.com
4.5L Low-buck simple stroker
~ Jeep 4.2L 3.895" stroke crank
~ Jeep 4.2L 5.875" rods
~ Jeep 4.0L 3.875" standard bore pistons
9.7:1 CR
~ CompCams #68-231-4 206/214 degree camshaft
~ Ported HO 1.91"/1.50" cylinder head
~ Stock 0.051" head gasket
~ 0.081" quench height
~ Ford 24lb/hr injectors with adjustable FPR or MAP adjuster for '87-'95 engines, Ford 24lb/hr injectors with stock 49psi FPR for '96 and later engines
~ 260hp @ 4850rpm, 321lbft @ 3500rpm
what else do i need mwith this to make it work? i looked on the compcams website and it says you cannot use the stock springs with that cam? just curious if there is anything else that is left out fo this list?
9.7:1 CR
