- Columbus, In
I know this has been thrown around all the time but i am thinking of doing a stroker. I ended up here looking at stroker setups: http://www.jeep4.0performance.4mg.com/stroker.html
Here is the setup i liked the most
Jeep 4.2L 3.895" stroke crank
Jeep 4.2L 5.875" rods
Jeep 4.0L 3.875" standard bore pistons
9.7:1 CR
CompCams #68-231-4 206/214 degree camshaft
Ported HO 1.91"/1.50" cylinder head
Stock 0.051" head gasket
0.081" quench height
Ford 24lb/hr injectors with adjustable FPR or MAP adjuster for '87-'95 engines, Ford 24lb/hr injectors with stock 49psi FPR for '96 and later engines
266hp @ 4950rpm, 322lbft @ 3500rpm
It seems like a good mix of power and economy as a matter of fact more than i need but thats ok for me and it won't need to be bored. This will be down the road a ways i'm just starting to do my research and this may be completely different than what i end up with. Since mine is a 97 i can run a 49psi FPR instead of an adjustable. Would I need to run premium gas with this setup? Will i be able to retain the stock computer?
9.7:1 CR
