C85D4x4
NAXJA Member #1311
- Ohio, Brecksville
SOUTHTEXASXJ said:The JCR has no brackets avail for the Disco's they said on the over knuckle you have to remove them.Mike at JCR says the under is the same just less clearence.
But the question is do I need the over with my amount of lift and if so what do I do for Disco brackets?
JKS sells Extended Swaybar Mounts
http://store.jksmfg.com/merchant2/m...0_915&Store_Code=JKS01&Category_Code=FABParts
You can also drop your swaybar down with some Swaybar drop brackets.
RE sells them, but there are easy to make your self.
