krelja
- New Jersey
raw
krelja said:From the looks of it its gonna take alot of $$$$$$ to get the front end squared away. I'll start withe the disco's, how much thread is left on those things? And as for the steering and track-bar situation my advice would be a 1-ton OTK with the JKS over axle track bar mount. It's not cheap but any off the shelf steering upgrade will not work well with that amount of lift and you need better steering. The trackbar you can make ith good components and if you can't weld bring it somewhere and they will do it pretty cheap. That trackbar looks a little scary to me
JNickel101 said:You really cant go wrong with either TNT or RE for trackbars. TNT will make a custom length one for you, if you decide you need an Over Axle bracket.
I'd do what krelja suggests - address your steering. JCR is a good one and JKS makes a nice Over Axle bracket - TNT makes one too, it is/can be incorporated with their D30 truss. I really like that setup, looks super clean and strong.
XJSpencer said:Check out JCR's prices for the one ton steering.
What size tire and which flares are you running?(if any) I had mine at 8.5" of lift and it sucked. Now it sit's at 6.5-7" and I'm planning on cutting my coils down a little more to more closely match the rear at 5.75" lift. That's with 35's and BW flares. I love how it feels now. The steering will be easier with less lift.
Just a suggestion. It's your Jeep. Do what you like. I wish some of the info on was here 2.5 years ago. It would have saved me some time and money.
SOUTHTEXASXJ said:ok I think I am going with this for the steering issue's
http://www.tntcustoms.com/page.asp?pageid=178
Mosephus said:This is an expensive opinion, but I would recommend WJ or the Tera Knuckle (or thier Full steering kit) with an over axle trackbar bracket. That will solve many of your problems and it will handle MUCH much better.
The JCR has no brackets avail for the Disco's they said on the over knuckle you have to remove them.Mike at JCR says the under is the same just less clearence.ColoradoRaptor said:JCR is a little cheaper and the equipment is the same!!! :doh:
