DrSockMonkey
- Washington
This thread should be called "THE BEST ELECTRIC FAN SET UP THROW DOWN."
DrSockMonkey said:This thread should be called "THE BEST ELECTRIC FAN SET UP THROW DOWN."
You be quiet! you forgot to change out your heater core...:nono: just careless...jrowell said:It's amazing that this thread has got over 1300 views. You talk anything about a fan set-up and people are interested...
DrSockMonkey said:You be quiet! you forgot to change out your heater core...:nono: just careless...
Crawlin_88 said:Don't mean to thread jack. But rockwerks would it be possible for you to take some pics of your set up and post it along with a parts list? I'm just interested in your set up.
rockwerks said:You are an inexperienced guy with some mechanical ability. good luck, maybe you should read up on how and why the cooling systems are designed and maybe you might understand the dangerous nature of this misguided project
DrSockMonkey said:Hey Barillim I Like you setup, I think I would do the mounting a little differently but I like it. I am converting to a 6.2l detroit diesel and need all the room in the engine bay. How long have you run these fans? Also, can you tell me about your "relay" setup. Do you turn them on manually or is it temp controlled?
Thanks!
Jeremy
rockwerks said:pics would be nice, also too deep of gears with only 33's you are running too many RPM's on the highway, I bet thats where its getting hot.. the coolant is moving too quickly through the system.
barillms said:Highway!!! real Jeeps can't be driven on the highway. Lol.
Well statedchondamx said:He's missing the point you all are trying to make to him....While your fan setup probably works well [enough] when it is working, your SOL if for some reason you cannot power any of those fans up. You will not even be able to drive at road speeds without overheating or getting close to it--and offroad is totally out of the question. I myself run a single old OEM Nissan fan on a relay and switch and I can sit in traffic all day and not over heat. And I can turn my fan off if I'm running down the road at more then 40MPH and it'll be fine even with my crappy OEM radiator with many a cooling fin punched out. Another point I'd like to make--I am a firm believer that for the most part OEM electric fans will be far more reliable in the long run than ebay specials.
-Chris
four_shot said:I'd be afraid of the shroud blocking the ram air. I do like the idea of putting the fans on the front though. it'd make water pumps and the like alot easier without the fan's and shrouds in the way.
igotanxj said:What fan are you using that has a thermal shut-off switch? I've never heard of the OEM electric fan doing what you are talking about and some people on here have put two of them side by side in place of the clutch fan. That sounds like a MUCH better idea than blocking off airflow at the front of the radiator. Pullers are more efficient than pushers anyway.
