rockwerks
- Chito Beach Resort, WA
Use stock setup and fix your junk instead of throwing money at it! gee what a thought!
slipslap said:And is your name taken from Dune's Paul Atraides? I love that movie.
SnagglePuss said:Movie? Blecchhh! The books were good, though...
Thats what I did and it works fine except for 4 wheeling with the AC on. Is anybody able to crawl and climb all day on a hot day with the AC on?rockwerks said:Use stock setup and fix your junk instead of throwing money at it! gee what a thought!
Stumpalump said:Is anybody able to crawl and climb all day on a hot day with the AC on?
Stumpalump said:Thats what I did and it works fine except for 4 wheeling with the AC on. Is anybody able to crawl and climb all day on a hot day with the AC on?
All the time,and it doesn't get much hotter than here!Stumpalump said:Thats what I did and it works fine except for 4 wheeling with the AC on. Is anybody able to crawl and climb all day on a hot day with the AC on?
vetteboy said:<- this guy
The only time I've ever had a problem overheating was when my radiator cap went bad and wouldn't maintain pressure. Never had a problem other than that, even on 90*+ days.
All three are seperate, on a seperate relay, on a seperate manual switch.DrSockMonkey said:Hey Barillim I Like you setup, I think I would do the mounting a little differently but I like it. I am converting to a 6.2l detroit diesel and need all the room in the engine bay. How long have you run these fans? Also, can you tell me about your "relay" setup. Do you turn them on manually or is it temp controlled?
Thanks!
Jeremy
rockwerks said:Ill give it 6 months before he forgets to switch on a fan and burn up the motor.
85xjwoody said:I don't understand why you still get that hot even if you said you replaced everything.:dunno:
Muad'Dib said:Ive wondered this also, because alot of people have "claimed" they have replaced everything and still have the running overly warm issue.
jrowell said:I don't know if this was directly aimed at me... but I'll respond. In the last 3 years in my 87 I have replaced: Radiator (twice. Switched to open) Water Pump (twice), Hoses (with spring) Clutch Fan (Twice) Newer Electric Fan, Transmission lines, ENGINE/head, TRANSMISSION/ t-converter, AND Tcase. Added Hood Vents. Put in External Temp Guage To confirm temps. Changed AC compressor.
I *think* that would qualify for everything 8>)
Through all of this, temps still run 200-to 210 with the AC off. If I turn it on while on the trail or a hill... 220+ easily.
I'm not "complaining". It is, what it is. I just want to use my AC when it's hot out on the trail and I have my two young girls in the heep with me! If that means adding a fan or two (or five) so be-it. But don't ASSume it's a "band-aid" or I'm "not fixing my junk!"
RCP Phx said:Catch 22,your motor is supposed to run at 210*,the real question is the capacity to maintain it under any circumstances.Theres a hell of alot more things that plays into this,first is proper gearing which seams to be the last thing folks do.Second would be HD trans coolers for those with auto's.
