cometcyclonemk
- Seattle, WA
Front axle installed! Found another for cheap with all brackets included. Will be posting up my 3.07 axles as well as the first 3:55 D30 soon.
Final install included:
New V8 Grand Cherokee Tie Rod, new drag link, new rod ends.
Rusty's adjustable track bar
New sway bar bushings.
Wrecking yard modified WJ Lower control arms.
Repainted my OME 3" coil springs, removed paint from Bilstein 5100s.
A couple of questions before I get to the pictures:
1. I'm getting a clunk when the driver's side tire hits a bump. Nothing on the passenger side. I can feel the clunk under the clutch pedal through the floor board. I've checked torque on everything, bushings are all new or good. No play can be found. I've cycled the suspension using a jack and having the neighbor jump on the front bumper and cannot recreate stationary.
Thoughts?
I stuck with the u-jonts and unit bearings on the axle I picked up. They don't seem to have any play in them. Tough to say on ball joints but they seemed fine as well. I'm inclined to think upper control arms given that I can feel it in the floor board but those bushings were inspected / good.
2. I can't quite seem to find a picture or good way to identify axles. The axle I originally bought has different u-joints than the one I installed. If one of them has the beefy later u-joints I keep reading about I'd like to keep them and swap eventually. How can they be identified?
3. The track bar weld rubs on my new Teraflex diff cover. Any reason I shouldn't just grind down the weld that rubs a bit or perhaps take a little material off the cover (it's advertised as 3/8" thick).
Thanks! Now pictures!
Thoughts?
