cometcyclonemk
- Seattle, WA
I don't think you will have enough room for the shock eyelet, and the shock body at full compression, I think to remove that much material, you will be removing the bolt holes, or at minimum severely weakening them.
Shock body shouldn't be an issue since most of the shocks I'm looking at mount body side up. Still might not be enough room though.
I did stumble across this image however. It's from a teraflex (TJ) LCG pro lift kit. Seems like something like this for our lower mounts would be a sweet solution to get rid of the bar pins & provide for a longer shock.
Hmmmm...
All jokes aside, do not just put two tabs off the lower control arm mounts like a noob.
Not planning on it. It seems like it could probably be done with enough reinforcement to work, but it's beyond the scope of my garage fabrication at this point anyway.
