xcm
- Southern Oregon
4. I would still be interested in the possibility of a 2" bypass shock providing some semblance of a bump zone during the last couple inches of compression. It looks like you've built one before, do you have more information including pricing?
Ok, so as an engineer you know fluids fallow the path of least resistance...
Bypass tubes BYPASS the shock piston... meaning you cannot make a shock zone stiffer than the static valving, you can only make it SOFTER than the static valving... An example would be the 'landing zone', ie from full droop to about an inch down on the compression side, you want this nice and soft to resist your shocks trying to resist a launched 5000lbs jeep compressing the suspension, you want a gradual cushion, but that 1-2" of travel moves FAST, then the rest of the shock does the rest.
Trophy trucks do what you are talking about, but they have bypasses for every shock zone, and run CRAZY STIFF static valving, then dial each zone in on that bypass. 90% of their shock movement is on the bypass's, the other 10% they want to be crazy stiff (like a bump zone)
I also dont think stock shock mounting is adequate to handle bumpstop loads either, but i could be wrong.
Anyway you slice it, not needed on a non race jeep. Its very telling that your tech support contact didnt get into this kinda stuff, but of course gave you a price...
