samger2
- Blacklick, Ohio
This has turned out to be the absolute worst job I've ever undertaken on this vehicle. I simply cannot get the oil pan back on. I've got the Jeep on jack stands on the frame, have the suspension at full sag, I've removed my center link, my stabilizer shock, my tie rods, my trac bar, my sway bar...everything is out of the way, I tried jacking the front axle up to ride height like other threads have mentioned...I simply CANNOT clear the front axle enough to get the pan in. I thought I had it so I put rtv on the pan and put the gasket on, it rubbed so much **** going up the gasket ended up in the pan.
I'm at a loss, I've been at this since Saturday, I have absolutely no clue how to get the pan back up without rubbing the entire way and having the gasket fall into the pan.
Suggestions please
2000 XJ
Suggestions please
2000 XJ
