- Rainy side of Washington
I would not weld the spiders on the front if you ever drive it on the street... unless you use a vacuum disconnect front axle, or get hubs for it.
i have a '79 f350 d60 in the front of my red p.o.s. on 39.5's w/ 5.38's, it is gross overkill. i love it. the brakes are friggin' huge! QUOTE]
Did you swap to 35 spline outers or are you on the stock set up? What are you using as a brake booster and master cylinder? Stock to?
Yes the garage is cluttered and filthy. Any other comments or advice?
I am possibly buying a HP Dana 60 from a 96 Ford. Its has a matching 8 lug pattern as the rear. I understand that it is has balljoints, but I am not worried about that. But if I read the 60 bible correctly the pinion is about 3.5" to the driver's side, I don't think that this will be a problem with setting up the coils, but I jsut wanted to know anyone has any personal experience.
Also I cut off the old spring perches and got some new perches for it. I don't have an angle finder so I was going to weld them so them so the pinion will be slightly above parallel. If I went out and got an angle finder I need to be about 11* right? I'm on about 5" lift. Also they will be welded about 6 1/4" from the drums backing plate. Will it be a big deal if I am off 1/8" on one side? Sound about right?
Advice/comments are welcome
$800 for a ball joint D60 is a lot higher than I would pay. Even with 5.13s.
I got my '88 kingpin HP60 for $200.
They must be a lot harder to come by out there.
