xcm
- Southern Oregon
keep us updated on the DIY trackbar mount (looks like ruffstuff?) the geometry on my ruffstuff was waaay wrong, and wouldnt work for me.
Finally got it all done here are some pics
Frame mount
In the first few pictures you had Rusty's upper control arms and in the last couple you have the factory upper control arms. Why the switch back?
I moved the bracket a little bit from stock and the mount was in the way of the bottom bolts. I didn't feel like putting the time into making a bracket that would reach the top bolts and contour to the frame.
People weld to the unibody all the time, we used a lower setting and focused the majority of heat onto the thick metal, we were very slow and it took a long time to do the frame as to not over heat the frame.
Yeah, thats a tight jeep and all, but i'm really blown away by how dirty your floor in the garage is, that would bug me to no end
could be a few things; bumpsteer, poor caster angles, poor toe alignment
Ok so I already have a small problem... It also feels like I am getting bad body roll when I turn. I can keep it between the lines but it takes so focus.
