Sero
- BC, Canada
I recently bought the 3 bolt steering box spacer, all the holes except the large one that dosn't bolt to the box lined up. The one that didn't line up wasn't even close.
You got a great bumper.. Mine and the wifes have the same thing
Pics? I have one and although it was a bit tight, I did get all 4 bolts in at the end. I'm dreading having to deal with the steering again. Conveniently, I forgot to paint it in something so now it's got a bit of rust.I recently bought the 3 bolt steering box spacer, all the holes except the large one that dosn't bolt to the box lined up. The one that didn't line up wasn't even close.
I'm having the same issue myself. I have sent an email to JCR just a few minutes ago ([email protected]). I just hope my fate with the steering box isn't the same as yours.
Yeah, I did not get my stickers with my shipment either.
I got my bumper and tie-in brackets, though! I sure hope my brackets fit.
I was just up at JCR's shop this past Monday, and they are having a little delay with stickers. So Eric told me as soon as they get some in, they will send me some. I would email JCR and ask them to send you some when they get their stock of stickers. Btw I got the same front bumper as you did, and I love it!
I'm running the winch version and had no problems getting the brackets to line up. I wouldn't worry.Yeah, I did not get my stickers with my shipment either. I got my bumper and tie-in brackets, though! I sure hope my brackets fit.
The hoop has light tabs on it, although you may need to space the lights up a little with washers depending on the lights My Hella 500s didn't clear the tube, so I used 3 washers as spacers, and they fit perfect.Dieselenthusiast:
Do you plan to remount those fog lights from the OEM bumper onto the new bumper?
If so, what are your plans?
Did JCR redesign the hoop? Or is that like a stage 4 bumper with an added hoop as opposed to the prerunner bumper
&^%$ I started on the bumper install today after work but had to put the original bumper back on. The uni-body tie in brackets need to have most of the holes re-drilled to accommodate the bolts. I could get the front two bumper bolts installed but I will need to drill the rest. Same on both sides. That should not be a real problem, but I was hoping to get this installed today.
I have managed to dent the tubes on the sliders though but nothing major.
Is this a JCR problem?
HOW? I hit a Mercedes with the drivers side one and it didn't dent. The rail made it through but the Jeep didn't!
Hahaha. I've beat on them pretty bad but one good sized dent came from Rattle Rock. I must say, the dent to the slider was small compared to the dent in the door.:laugh:
might be a bad batch, mine lines up fine.
