Roxtar
- NW Indiana-Chicago area
By greasing these you not only fill the caps with grease like all greasable joints, you also fill a small spring loaded cylinder with grease. This constantly forces grease into the joints. It's like greasing them every day.Big Red said:Why do you like the unpressurized grease feature? I think I greased my OX u-joints without removing the tire. It is very easy though to break the needle grease fitting attachment on the gun. How much are the Jantz joints? Still around $70 a piece? I didn't think they were still being made? So the Jantz are the same 4340 alloy as the Yukon Super Joints? I thought they were just 760 u-joints with bronze sleeves instead of the needle bearings in the caps.
After having the OX u-joints for a little bit, I really like them. I just wish I had the 2nd generation ones that have grease fittings on each cap rather then having to grease the fitting in the center of the body. They are fully rebuileable and easy to work on. They are totally a different direction in u-joint design by not having snap rings and instead having an internal trunion retainer. They are like a puzzle and have a # of pieces.
All the Ox joints I've seen need the axles removed to grease them.
As for them being bronze sleeved 760s, I think you're confusing them with Longfields. The Jantz/Yukon Superjoints are completely machined out of a block of 4340 and they're every bit as nice as CTMs. They have no sleeves and are $270/pair.
