kid4lyf said:
Exactly.
That's complete BS.
What good is their warranty then. With their axles the U-joint is the weak link.
Big deal, with Spicers the U-joint is still the weak link.
Even with good high end joints the axles should still be stronger than the joint.
That makes their axles no better than Spicers. They are only as good as the weakest link, which is the same in both.
Basically, Spicers with CTMs are stronger than Warns with 760s.
Big misunderstanding here......
A 760x axle u-joint that is full circle clipped or tack welded is as strong or stronger than the ears on a Spicer axle yoke. In most situations the ears shear off the yokes and the joint may or may not break. The yokes will also stretch around the u-joint caps leading to that type of failure. A 760x joint used with a chrmo axle is much stronger because the yokes are so much stronger, won't stretch or shear off, so the joint becomes the weak link again. Additionally, I've never seen an axle joint break and not also take out the Spicer yokes, but a chrmo axle will usually not be damaged by a broken joint, so only the u-joint needs to be replaced. Using a CTM or OX u-joint on a Spicer axle is a waste since the axle yokes will break way before the u-joint does. If someone just can't spring for the CTM or OX, and doesn't run over 35" tires, a snap ringed 760x joint on chromo axles is not a bad way to go, and a cryogenically treated 760x joint is even better. Of course, by the time you buy a cryo'd 760 you aren't that far from the price of a Longfield.
It makes sense that Warn won't warrenty their axles if it's not the axles fault. They want you to send them the broken axle so they can inspect it. If the yokes are all beat up from driving on a broken axle joint, they're not going to warrenty it.......which is what was happening at first with these shafts. If you break a joint, stop immediately and fix it (you risk breaking the knuckle if you drive, anyway), and the Warn shaft should be OK. I hadn't heard that they wouldn't warrenty a broken shaft if you're running super u-joints, but I can't blame them. When those shafts were originally put on the market, there were no CTM's or OX joints, and the axles were made to be stronger than the 297x/760x u-joints.
Earlier this year FarmerMatt broke the yoke on a Warn shaft, and they warrentied it with no problem.
