I have DW at weird times in my 98' XJ. I can feel it coming on and then slow down before it strikes full force. I added a 2" BB with spacers and blocks, but didn't get a alignment yet. How much out of alignment can a 2" spacer lift put you? I bought this Jeep in Illinois and drove it cross country to Cali (2,200 miles) with no problems, so I really think it needs a good alignment. This Jeep was stolen and quickly recovered recently in Cali, so it is possible it was joy rided a bit. My Jeep was missing the tires/rims and few other things like floor mats and steering wheel cover. It was suprisingly spared past these items I lost and I put on a set of tires and drove it the 5 miles back home. I didn't drive the Jeep that much so hopefully it just needs a good alignment, I tried jiggling stuff and everything appears tight with no play, including the ball joints by trying to jiggle the top of the tire with the weight on tires. Should I lift the Jeep and try jiggling the tire to diagnose bad ball joints?
I had death wobble a few blocks from my house doing like 50 or so, slowed down almost to a stop, it went away and then I still drove another 10 miles staying under 70 and didn't feel it starting again, drove back home (another 10 miles and no DW). It's so frustrating, because you'd think you'd have when you drive over a certain speed, or a hit bump etc, but it sometimes comes and other times it's fine. I tell you that after you have DW, you are very cautious. I had it at 90 for the 1st time and was totally scared, I thought it was my crappy tires that are almost all the way worn, but now I put on some good street tires 235x75x15 and I still have it.
I had death wobble really bad on a $300 91' XJ I picked up, it had bad tires and once I replaced them, it was gone. Thanks for getting this poll thread set up, it should really help that we can at least point to some concrete things like the track bar, or worn bushings, steering ends and hopefully cure it. There are so many things it can be, but this thread helps a lot and you can see some trends.
Troy
