Cruzin Illusion
- Commerce City, Colorutah
Capt. Nemo said:What will be off .66" to the driver's side?
The TNT Conversion kit is design so that you really don't have to take any measurements. With that said the upper and lower control arm attach points will be off along, with the coil buckets if you shorten the axle to a waggy width using waggy axle lengths. The pinion I don't think really matters being off .66" The kit was originally designed to put full width HP44 in XJ's, ZJ,s and TJ's. Along with YJ's if you run their coil conversion kit. I spoke with Matt at TNT about making a truss that moves everything .66" over for the guys that want to shorten their axle to a standard waggy width, but then you start running into problems of the driver side coil bucket getting into the casting of the center section. So all I am saying is if you would like to run a true Waggy width so you can run stock waggy axle shafts your front axle will track .66" off to the drivers side.
