-96JeepSpeed-
- Tweaker Valley CA. (Spring Valley)
Ehh, TONS of people do it, with successDoing this puts too much stress on the passenger side knuckle.
Like was mentioned before, check your caster.
I dont think so. If so thats a prett Fawked up setup, Why the hell would somebody do that??For the second time, his RK steering is set up correctly.
Either the 22 year old offroading vet was wrong or you misunderstood him.That's not what I was told when I had my rig inspected by an off road specialty shop. They told me if the suspension cycles and your steering turns or jerks during this cycle then it's bumpsteer. For instance, when I would climb over this 1 foot rock, my steering would turn to the left on it's own and I would have to correct it. The cause of it was the drop pitman arm putting the draglink out of sync with the trackbar. Once I removed that drop arm, the bumpsteer was gone and i could cycle the suspension with zero movement in the steering. It made perfect sense to me. Perhaps the 22 year off road vet was wrong........or it's the same thing, explained differently??
So how does it flex with the Mis-alignment spacers already maxed out on the drag link just sitting on flat ground??
http://www.kentongrayracing.com/racing101.php
http://www.tireboys.com/expert_lexicon.htm
http://motortrend.automotive.com/34571/112-9607-technical-terms/index.html
But the thing is, If it were lower, and the heim wasnt maxed out, What do you think it will look like at full drop with/o straps? Maxed out.he has exceeded the recommended maximum lift height for that steering setup.
That is the strangest setup I've ever seen. I didn't think it was installed right at first, but it looks pretty close to the mfg. picture in the directions. It still seems to me like the tracbar would need to be lowered at the axle end to be "right".
Brackets dont really count,but those CA angles are out of this world!
Alright so like I said I took out the 2inch spacers.
It looks like my axle is really angled down. The lower control brackets are angled really bad also.
I just want to get this dialed..... Getting death wobble crusing at 80 on the highway is scary as shit lol
