Ok re-reading and sorting out who had what symptoms again (got thrown by someone else chiming in about an error 66). Holler if I missed something badbowtie87.
Symptoms:
In D, it's starting in 3rd or 4th. Shifting manually it goes from 1st to 3rd very quickly and doesn't kickdown under throttle. TCU pins have power and good ground. #2 shift solenoid has a high resistance. You see power at appropriate shifter sense pins when moving the shifter. Swapped TPS, MAP, and TCU. Cleaned NSS.
Can you clarify what it's doing if you put in (1-2). Does it upshift at all or stay in 1st? If the TCU is dead (1-2) should stay in 1st, (3) stay in 3rd, and OD should stay in 4th. If it's upshifting then the TCU is doing something.
Can you check if solenoid #1 is getting power with the ignition on in park. Below is the chart for the solenoids. Solenoid #3 is the torque converter lockup. The solenoids only have a single-wire connector so they get grounded through the tranny chassis. I don't recall if there was a dedicated ground wire from the tranny in the wiring harness (there is one from the speed sensor as I recall). Verify that you have a good ground from the tranny to the body and battery.
Shifter Gear Energized Solenoids
P Park #1-on, #2-off
R Reverse #1-on, #2-off
N Neutral #1-on, #2-off
D First #1-on, #2-off
D Second #1-on, #2-on
D Third #1-off, #2-on
D OD #1-off, #2-off
3 First #1-on, #2-off
3 Second #1-on, #2-on
3 Third #1-off, #2-on
1-2 First #1-on, #2-off
1-2 Second #1-on, #2-on
So regardless of shifter position and the NSS output, you should see #1-on, #2-off when the vehicle is stopped. That high resistance on the #2 solenoid is suspicious.
-Chris
