609 and 13 bolt
The tight fitting tube work looks good.
Thanks man. I got the t case and trans mounted. Got the t case shifters set up and started working on the new crossmember. Next time I'm home I should be able to finish up the x member and fill in the hole in the trans tunnel and get the seat remounted. I'm going to try to make the filler piece removable.
