barillms
- Eastern Ohio baby!
My Jeep was running hot, and I initially went the "Taurus" fan route.
Electric fans are great except for a few problems I encountered.
I've exhausted the cooling fan options to the very end, and this is BY FAR
the best solution there is out there.
The problem with the XJ radiator, is the shape. It's NOT a square like some truck radiators... or CJ or YJ radiators. SO, you plop a 14" or 16" fan behind the radiator pulling air, it's a waste!!! It's doesn't fit, the fan hangs down below the radiator and isn't doing what's you're intending it to do.
DONT BOTHER WITH A BIG FAN, or TAURUS FAN in an XJ or MJ.
Electric Fans have built-in thermal shut off points. Your engine is hot, on a 90 degree day in August, the engine compartment is like an oven.... just holding all the heat in there. Sure, you can vent the hood (I did) but it's still hot in there. Having "PULLERS" behind the radiator isn't good, because when the engine gets hot... the fans will SHUT OFF, then you're done. Now you have nothing.
#1 the fans must fit the radiator. 10" fans are THE ONLY fans that will fit our radiators and move air through it efficiently. REVERIBLE "S BLADE" FANS MUST BE USED. They are $25 each on ebay.
#2 putting fans in FRONT of the radiator, away from the hot engine is the BEST IDEA because they won't get hot and quick working.
#3 THREE CHEAP 10" electric fans from Ebay fit inside the XJ grille area
PERFECTLY across the front.
#4 They MUST be very sturdily mounted onto a sheet of 1/4" plastic,
while not warping or bending the fan shroud causing the blades to rub.
Here's how to do it:
