- Michigan
My thoughts would be you do not want it to flex. I would think you would be more stable on the trail with the sway bar. I could be wrong
Flex is irrelevant on a trailer because your tongue does all that work.
If its swaying badly going down the road, put the sway bar on. If its stable, don't worry about it.
Seriously though you don't need to worry about flex on a trailer. Flex helps keep traction on tires that have power going to them. It doesn't matter on a trailer. Sway on a highway is a bigger issue though.
You don't need a sway bar on a trailer... the suspension does not articulate per se. It just moves to absorb bumps.
If your trailer sways at highway speeds it's because the loading is wrong (too tail heavy).
Sway bars are mis-named - they don't do anything for sway. The correct name for a sway bar is "anti-roll bar" because it restrains body roll.
Maybe just get an extended shackle to add a little more height?
I also want to stiffen the rear up so I was thinking of getting some cheap Full leaf packs like these stock HD ones 1.5" lift?
http://www.ebay.com/itm/321151793092?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
or these 3-4" ones http://www.ebay.com/itm/330873196719?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I am leaning toward t he 3-4" ones since as it sits the trailer tilts up a touch toward the rear of my jeep.
I figure it would be a waste of $ to get the matching Old man emu leafs that are on my XJ.
I wonder if I could get away with the cheap stock length shock since the sway bar wont let it move a whole lot anyway.
Any of the guys that saw this thing on the trails can tell you it needed stiffening up. Mark and Ed gave it the nickname the Weeble Wobble, after driving right behind us and watching it sway and hop and jump and bounce up on one tire.
Weebles Wobble But They Don't Fall Down!
You could always go really cheap and do a lift block. Sway isn't really going to be controlled by springs. That's shocks and sway bars.
