- sacramento
Thank you! It’s pretty awesome, not gonna lie.
Had to tear my tcase down again because the chain was skipping teeth, so I ordered a new chain and sprockets. Pulled it apart and found the range fork almost totally worn out after about 1000-1500 miles on the new one. I’m not sure what’s causing the range forks to wear out so quickly. If anyone has any insight on this I would greatly appreciate it.
Did you put the detent spring and detent ball for the range fork in backwards? I had a messed up range fork (almost totally got) and when i pulled the case apart I found the detent spring and ball in backwards. Then I said screw this and ordered an atlas because I wanted an atlas anyway
