WJ knockles
polar_jeep_04 said:
so is there a way to tell which is which with out having them side to side?
The Teves are Black and the Akebono's are silver/gray.
XJSpencer said:
Cal. Follow the directions. No problem.
With the 5x5.5 kit and WJ knuckles supposedly I have to machine .230" from -some- surface.. but people dont seem to remember which one. :)
I didnt get directions with my parts, they came off of another rig. I probably just need to dig into it and make it up as I go along.
Really?! Hell mine are silver! Maybe I got Akebono's. I just assumed they were Teves because they fit well and I thought I recalled seeing Teves stamped in them.
What Tracbar bracket did you use? Or did you make that one?
My teves are silver. In fact, I have two pairs that are silver.
I guess that info I had was wrong.:D I thought I got that from the dealer. Who know what I have then?...I'm pretty sure they're Teves.
Cal. I'm guessing the rotors have to be machined to fit the bigger hub.
edit: I got it off of Car-Part.com
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Caliper[/FONT]
Rear, R.
Rear, L.
Front, Continential Teves (black color), R.
Front, Continential Teves (black color), L.
Front, Akebono (silver color), R.
Front, Akebono (silver color), L.
This service uses Car-Part Interchange
By clicking on "SEARCH" You agree to the Web Site User Agreement.
Yeah I have to figure that out. Some people claim to run re-drilled WJ rotors, others CJ7 rotors. The kit I have has rotors with it, but I dont know which ones. I may just bolt it all up and see what happens - but I hate going into a project unprepared.
the 5x4.5" hub kit is suggested by warn not to use on anything bigger than 32" tires.
The "bigger than 32's" kit is a 5x5.5 bolt pattern.. (which is why i'm installing it). I wouldnt bother if you arent changing bolt patterns.
Since this thread started about "knuckles",might want to consider the Tera-flex.No mods other than steering/trackbar.No spacers/calipers-rotor issues/hub issues/no ball joints/!
I think my rig stopped better with stock XJ brakes than it does with WJ brakes - once I put a WJ master/booster in.
So what was your prime reason to adding the hubs? Just to change the bolt pattern? Seems awefully pricey for just that...
lowrange2 said:
But then you still have crappy brakes for the same prices as 2 knuckles, 2 calipers and discs. Just not my cup-o-tea
Like I said,this thread started about knuckles only,so I was leading to a OTK steering suggestion only!
No other mods required.
RCP Phx said:
Like I sais,this thread started about knuckles only,so I was leading to a OTK steering suggestion only!
I got ya.
As far as the stock brakes working better. My WJ brakes work WAY better!
Not pricey at all. I bought a set of champion beadlocks from a friend, and he threw in the 5x5.5 hub kit free - had it sitting around from his old dana 30.
Locking hub kit.
Right now I run year 2000+ 30 spline TJ unit bearings with alloy usa 30 spline stubs.
I'll be going to the warn 5x5.5 locking hub kit, 30 spline. I like the idea of locking hubs, but I'm more interested in the change in bolt pattern.
