Today I yanked the drivers side fender and installed the new one.Got the last tube bent, cut cut the fender, welded a little, and re-installed the bumper (sorta).
Well bending the metal for the rear tube fender simply wasn't going to happen. Guess I trimmed a bit too much when I installed the Bushwhackers...lesson learned.
In this pic you can see the gap just behind and slightly below the door.
Since Had some 16ga leftover I decided to use it to plate the body at the forward part of the wheel well. This pic shows the rough contour of the plate I fabbed up..
Here's the almost finished drivers side.
FWIW, the gap was bigger than what it appears to be in the first pic. Probably due to the coat of rattle can I sprayed on. Nothing shows flaws or areas that need some more work like a little paint.
Since I needed the garage tonight for another project I had to re-install the bumper/carrier temporarily and park it outside....time for a pic or two!!
Daniel just couldn't resist testing the fenders...
Yep, welded. Don't know if it will take a hard hit or not...hope I never find out. Still need to add another support in the center of each flare as well.
