sbilbrey
- Marysville, Ohio
1998 Cherokee Sport, 150K Miles, totally stock. There is a ramp in my town where there is a transition from concrete to asphault with a large bump while turning. Going over it at about 70 to 75 the steering wheel shuck violently for a couple seconds.
I figured something was loose in the front end. Following the Haynes manual I jacked one side at a time and checked for movement in the lifted wheel. Both felt very tight. While I was in there I replaced the front brakes. While it was in the air I lubed the front end. I also had someone turn the wheel from side to side while I looked for anything wrong. I could not find anything. I also rotated the tires while I was working.
It feels better now, but it does not feel as solid as I think it should. My next guess is the dampner shock. Maybe a front end alignment, I am not thinking this will fix it, but maybe the shop will report an issue.
Does anyone have any ideas/suggestions?
Thanks,
Sammer
Thanks,
Sammer
