- Southern Maryland
I think some of you people are confused--the JK axles cost about $1500 each, or about $3k for the pair
The pictures I posted is a high pinion D44 from a '77 Ford F150 that I narrowed down to a custom width but cutting off and re-welding the inner C's back on.
The way you suggested would be a more time and work consuming way of narrowing the axle. It is easier to cut the inner C's off, cut some of the tube down, then weld the C's back on.
You would need two axles to do that, which would mean more money, and just a lot of extra work. You would also need to get the axle tubes out of the housing, which isn't the easiest thing.
Wait hold the phone, the TJ44s are Low pinion???? Damn
Grind out the stock shafts for full circle c-clips.
It will help them survive a little longer.
Could you elaborate?
For photo reference in case anyone searches later:Could you elaborate?Grind the inside of the ears of the axle shafts so that you can put a full circle snap ring to retain the caps. Its stronger.
For what its worth, I know a hand full of TJ guys on 36"s fully locked, geared low, with their stock LP30s, and I can't remember anyone breaking.
TJs = LP30
YJs = HP30
