billyjp2
- Indian Orchard MA
JK 44s are notorious for bending tubes even during mild offroading
The JK D44s are not bolt in, I think the UCA mounts might be close if I remember correctly, but the LCAs are not. You will have to redo all the bracketry. They are also 32 splines compared with 30 splined TJ shafts. The carriers and gears are different than other D44s. They are also wider than stock XJ axles, and have a 5x5.5 pattern.
Never herd of that one.. but i would think you can brace them as you can D30's
I havent heard that either, are they weaker than a d30s tubes?
My bad.They have a 5x5 pattern, not a 5x5.5.
The waggy shaft minor diameter is actually smaller than the D30 axle shaft minor diameter because of the neck down at the carrier. I sheared mine at the neck down my first run after building the 44. They are definitely a worthwhile axle with chromos though. With chromos and superjoints mine ran around $2700 IIRC.I would not build one either. If I wanted to drop coin into an axle for my XJ I'd do up a 9" or a 60.
I would run one (Waggy D44) in stock form though. A lot stronger then a stock D30, especially an early one like the one in my 90 with the 260X joints.
I don't regret dropping the D44 in my 71 for the D60. Might drop my D61 into my 63, after it gets regeared. 3.07's and a 230 OHC 6 would not be pleasent.
damn, i was quoted $3800 for a locked and shafted and welded up 44 with the works built and put in a crate and shipped to me.
