Blaine B.
- Northwest Indiana
I think I have a basin wrench lying around somewhere. So just try that on the torx bit itself after punching it out of the socket. I think the torx bit itself is too small for that wrench....just guessing as I am not actually looking at it infront of me.
Danman, did you punch that T-60 bit out of the socket too and then use a wrench? I still can't see that bit fitting a 17mm wrench! If it did that would be ideal......but the two I had, one fit a 10mm and the other fit 1/2"
17mm is about .67" isnt it?
Anyway even then I snapped the wrench in half (without welding) and I was having difficulty with the torx bit sliding in the wrench back and forth. When it was sliding it was very difficult to get the bit into the torx bolt on the oil filter adapter square to make sure I didn't round anything off!
