Ok, I got the truss welded on, the holes in the axle tubes welded in and sanded smooth. The holes are all drilled in the brake backing plates and axle retainer plates.
I pressed the new bearings on the carrier and pinion and had a couple iterations to tweak the final setup numbers. Bottom line is about 8.5 thou of backlash and 14"# of pinion preload. The chunk is all buttoned up, lock-tited, and torqued down with the U-bolt yoke.
The axle shafts are cleaned up. Got all the rust off them and sprayed them with some primer. Got the wheel studs pressed in but haven't gotten to pressing the bearings on yet.
Lately, I've been working more on brakes. I got the calipers and rotors painted with Hi-temp paint, the soft line tabs welded on, and started bending hard lines.
Some of these will be out of order but oh well...
The socket head cap screws for the brake backing plates. Had to sand down a flat so that they would sit right on the tube flange...
The truss before welding...
The support bars on the truss. Axle straps will fit between the end of the truss and the support bars. Drilled and tap'd the axle tube for 1/4" NPT for the breather line. It's just on here now to keep junk out of the hole.
Here's the axle retainer plates with the new holes drilled. These are the rubicon plates modified.
